Hello everyone, when I import AllEntities.twx in composer ,error occurs. The tip is that Error importing: error, Import Failed: Unable To Convert From org.json.JSONObject to NUMBER.
Awaiting for your reply, thanks very much.
Regards
Sponse
Hi @sponse, I'm not sure what could be the reason, are there any remote things that to be exported? Can you try the other entities excluding the specific things mentioned in that log?
Hi @sponse, are you trying to export from one ThingWorx to another?
What is the version(s)?
I guess you can check this one:
Hi @sponse.
If one of the previous responses answered your question, please mark the appropriate response as the Accepted Solution for the benefit of others with the same question.
Thank you for participating in our community!
Regards.
--Sharon
