Hello Team,
importing Windchill extension 1.6 to TW 7.3 showing error as Extension must have a metadata.xml file , can you please suggest .
-Shripad
@Shripad Try unzipping ptc-windchill-extension-1.x.x\ptc-windchill-connection-extension . Import the ptc-windchill-connection-extension.zip extension and make sure it get successfully imported..
-Durgesh
@Shripad This could be due to the fact that you might be importing the incorrect zip file as extension. Request to please try unzipping and see if there are more .zip files as the package might have other dependent extensions which need to be installed or can be installed.
Note: In an extension zip file, you should have a metadata.xml file directly inside the folder structure which could be seen once unzipped.
-Durgesh
Hello Durgesh,
Thanks for quick reply .
I have checked in zip file it does not contain metadata.xml .The zip is downloaded from PTC website .
Even more checked other Windchill Extension zips 1-7-0, 1-7-1, 1-8-0 can not find metadata.xml when zip is extracted.
Installed TW veersion 7.3 & trying for Navigate configuration . Attached the information from Support Matrix.
Please suggest.
-Shripad
-Durgesh
Hi Durgesh ,
Its successful now.
But stuck up at importing "ThingWorx-Navigate-View-PLM-App-Extension-Bundle"
showing following error w, any inputs?
Error parsing C:\ThingworxStorage\extensions\temp\ThingWorx-Navigate-View-PLM-App-Extension-Bundle-1.6.0-01_8a228e6d-6f38-4311-9229-ef6a5ceb410d\ThingWorx-Navigate-View-PLM-App-Extension-Bundle-1.6.0-01\MockProviders_ExtensionPackage\metadata.xml: (1, 401): cvc-complex-type.3.2.2: Attribute 'licensed' is not allowed to appear in element 'ExtensionPackage'.
-Shripad
Hi Shripad ,
Are you able to solve this issue.
I am also getting same error while importing thingworx navigate framework extension.
Hi Vinay ,
Yes I am able to import thingworx navigate framework extension as followed by Durgesh suggestion.
Stuck up at Import PTC Navigate View PLM App Extension.
-Shripad
@Shripad: From the error shared it seems you are trying to use a Paid extension for which you do not have license. Please check and ensure you have rights to use.
-Durgesh
Hi Durgesh,
Any idea from where we can get the trial version of "PTC-Navigate-View-PLM-Apps.zip " & "ThingWorx-Navigate-Example-1.6.0-01.xml"?
Thanks & Regards,
-Shripad
