I am trying to import the Datashapes and Things in .xml format. I placed the files in system repository and tried to import it with import as source control entities. It shows import succeeded but I am not able to find the data shape.
Please help me resolve this.
Shalini V.
you can directly use the import from file option if you have few files in XML format
try doing that
and in parallel check application logs to find any error related to dependencies.. in that case import that dependent entity first
Are there any errors in the application log?
try doing that
If one of the previous responses helped to resolve your issue, please mark the appropriate one as the Accepted Solution for the benefit of others with the same issue.
Regards.
--Sharon
