can I merge recode that same timestamp
this is code to table
You can do that using intersect. You can even use multiple columns and different sort of joins as in SQL.
thank you for suggestion
now I create database thing and connect to thingworx db
then I create SQL Statement to query and join record in valuestream table
Hello @AL_10742319,
It looks like you have a response on your topic. If it helped to answer your question please mark the reply as the Accepted Solution.
Vivek N.
Community Moderation Team.
