I have an infotable which conatins timestamp, device_name, temp columns.
I need to apply pivot inorder to get device_names as fields w.r.t temp column as values.
My pivot code is:
var params = {
t: data /* INFOTABLE */,
nameColumn: "DEV_NAME" /* STRING */,
valueColumn: "temp"/* STRING */,
timestampColumn: "timestamp" /* STRING */
var result = Resources["InfoTableFunctions"].Pivot(params);
and i'm getting error like this:
"error": ""
please help me out...
I reproduced your pivot question and for me it works without a problem.
That is the infotable, which I used as a basis:
After executing the service I got the following result:
I guess that meets you expectations.
Can you please check - name column attribute. (You were writing "DEV_NAME", but mentioned in your text above device_name)
A second thing you could check is the output of the service, that this is set to infotable. (As I cannot see that from your description)
Hi @serler
Thank you for responding.
I have checked my column names. Those are right.
I am getting valuecolumn from a switch case. please follow the below full code
// result: INFOTABLE dataShape: ""
var data = me.QueryPropertyHistory({
oldestFirst: undefined /* BOOLEAN */,
maxItems: undefined /* NUMBER */,
endDate: undefined /* DATETIME */,
query: undefined /* QUERY */,
startDate: undefined /* DATETIME */
var value_col;
switch(parameter_name){
case "TEMP" :
data.RemoveField("HUMD");
data.RemoveField("CO2");
data.RemoveField("VOCtvoceq");
data.RemoveField("VOCco2eq");
data.RemoveField("DUST_PM2_5");
data.RemoveField("DUST_PM10");
data.RemoveField("DEV_ID");
value_col = "TEMP";
break;
case "HUMD" :
data.RemoveField("TEMP");
value_col = "HUMD";
break;
case "CO2" :
value_col = "CO2";
break;
case "VOCtvoceq" :
value_col = "VOCtvoceq";
break;
case "VOCco2eq" :
value_col = "VOCco2eq";
break;
case "DUST_PM2_5" :
value_col = "DUST_PM2_5";
break;
case "DUST_PM10" :
value_col = "DUST_PM10";
break;
var params2={
valueColumn: value_col/* STRING */,
var result = Resources["InfoTableFunctions"].Pivot(params2);
based on the information you provided I cannot see anything, which would cause the error in Pivot, sorry.
