My question is: How could I change the "isConnect" property to True? I've tried to change the isConnected directly, but it is not possible. I'm using the trial version of ThingWorx.
Pretty sure this toggles based on an Agent or System actually being connected.
So if you need something you can manually toggle, you'll need a new property.
Hi @charlo.
If the previous response answered your question, please mark it as the Accepted Solution for the benefit of others with the same question. If you still have questions, please let us know.
--Sharon
