issue of storing log data to valuestream
yonkim
Currently we are saving log data in valuestream via EMS with the setting below.
  • Data Change : Always
  • Scan Rate : 1000ms
But, I though log data would be saved in value stream once every second, but seems three or four data entry are being saved every second. Which parts should I check??
I attached my microserver folder.
2 REPLIES 2
Aanjan
(To:yonkim)
Yong June, are you logging multiple properties? Or is a single property logging duplicate entries?
yonkim
(To:Aanjan)
It is our customer issue.
Multiple properties in Multiple Things are logging to same valuestream.
Multiple Things are similar to each other.
Our customer has one more issue~
refer to  is there valuestream limitation?
it is critical issue~~ please help us...~~
Regards~~
