I'm trying to install thingworx foundation 8.4 using postgres installer. It is failed due to some error, the below content is in log file
Executing sc
Error running sc query Thingworx-Foundation: Program ended with an error exit code
[16:20:13] - Valid Java executable path: C:/Program Files/Java/jdk1.8.0_92/jre/bin/java.exe...
[16:20:13] - HOST_JAVA_HOME path: C:\PROGRA~1\Java\JDK18~1.0_9\jre...
I referred the above 2 article and my Environment variable are:
JAVA_HOME is set to --> C:\Program Files\Java\jdk1.8.0_92
PATH is set to --> C:\Program Files\Java\jdk1.8.0_92 ; C:\Program Files\PostgreSQL\9.4\bin
still I'm getting the same issue.
Hi @effpt3.
I encountered this problem with the SQL Server installer and we had to do two things:
If you have other java versions installed, these may be interfering with the install if they are included in the Path.
Regards.
--Sharon
I Put the JRE Path as well, still not working.
Hi @effpt3.
Would you mind if we opened a support case for troubleshooting this issue? I'll be happy to open it on your behalf.
Regards.
--Sharon
Hi @effpt3.
Just following up to see if you have resolved your issues with the ThingWorx Foundation 8.4 installer. If so, please post the solution here and mark it as the Accepted Solution for the benefit of others on the community.
Regards.
--Sharon
