js code
AP_9587236
js code
I need to return a string of words without using comma and in output every word should come in a new line. Is this doable?
For example,
"äpple
mango
strawberry
guava"
You can try with new line character in the string and use value display widget and format it as html. So you can see the changes as per your need.
Regards
Shyam
Regards
Shyam
slangley
23-Emerald II
(To:AP_9587236)
Hi @AP_9587236
If you found the previous response helpful, please mark it as the Accepted Solution for the benefit of others with same question.
Regards.
--Sharon
