kepware machines and tags configuration
SOLVED
Is it possible to bind the kepware channels in a combo box and when I choose one channel it should populate the respective tags in that channel.
For eg: If there are two channels, Equipment 2 and Equipment 2, I need to bind these two channels in a combo box. And when I choose Equipment 1 from combo box the tags inside the Equipment 1 has to be populated in another combo box. Same has to be done when I choose Equipment 2.
Thanks in advance,
Shalini V.
1 ACCEPTED SOLUTION
Highlighted
Re: kepware machines and tags configuration
The Industrial Thing that is mapped to your kepware server has services to retrieve the tags and its hierarchy, so you should have the ability to do something like you are looking to do.
1 REPLY 1
Highlighted
