label should display different text for every 5 seconds
dheerajkumar
I have a label and I want to display different text for every 5 seconds to the same label. like "a" then after 5 seconds "b" then after 5 seconds "c".....is there any way to accomplish the task. I tried using setinterval but didn't work.
You need to use Auto Refresh widget, which generates an event at a given interval. You need to bind this event to some data source (a service or an expression, for example). Finally, you should bind the result of this data source to you label.
/ Constantine
