1. I have one question about line chart. I have used get property values for data stream, when i use query property history the red triangle is shown in line chart.
2. I vant to have countinous data stream on display in line chart but instead the xaxis is moving around, what can i do?
Hi @SB_9802240.
Question 1 sounds like a permissions issue. Have you tested under the Administrator user account (not an account in the Administrators group)?
Question 2 is unclear. Can you provide more information and possibly some screenshots to clarify? We assume you have a refresh configured.
What version of ThingWorx are you running?
--Sharon
Hi, slangley,
thanks for answer. Im using TWX 9.1. Im using it with administrator account.
the second queation: I will send more images on monday.
thanks,
SB
I had tested with administrator accound and still the red triangle is shown in line chart.
The second image present whats is moving arround (Left and right).
thanks for answer,
SB
