line chart
SB_9802240
7-Bedrock
line chart
1. I have one question about line chart. I have used get property values for data stream, when i use query property history the red triangle is shown in line chart.
2. I vant to have countinous data stream on display in line chart but instead the xaxis is moving around, what can i do?
slangley
23-Emerald II
(To:SB_9802240)
Hi @SB_9802240.
Question 1 sounds like a permissions issue.  Have you tested under the Administrator user account (not an account in the Administrators group)?
Question 2 is unclear.  Can you provide more information and possibly some screenshots to clarify?  We assume you have a refresh configured.
What version of ThingWorx are you running?
Regards.
--Sharon
Hi, slangley,
thanks for answer. Im using TWX 9.1. Im using it with administrator account.
the second queation:  I will send more images on monday.
thanks,
SB
I had tested with administrator accound and still the red triangle is shown in line chart.
The second image present whats is moving arround (Left and right).
thanks for answer,
SB
Hello @slangley
can you help me with this issue?
Have a nice day,
SB
