why in thingworx 9.2.3 version for script logs info and debug logs are not coming. Only warning and error logs are coming?? how to change this settings??
Have you check the log settings? You may have to 'lower' the log setting to publish debug and info
Hi @AP_9587236.
If you found the previous response helpful, please mark it as the Accepted Solution for the benefit of others with the same question.
If you need further assistance, please let us know.
Regards.
--Sharon
