multiple file upload
Hariharasuthan
Dear all ,
  i want to upload multiple files from my local machine to the system repository. help me by sharing the thingworx service code
@Sathishkumar_C  is correct.
And if you are running a newer version of thingworx, you might want to have a look at the newer file upload widget information.
Here: File Upload Widget
Basically, there is no need for a service as the widget will itself upload the files.
Jens
5 REPLIES 5
Make "MultiFilesSelect" property to true in File Upload Widget.
Refer here.. File Upload Widget
Jens
SKannapiran
(To:jensc)
@jensc & @Sathishkumar_C - Through a service call, we want to achieve the file upload functionality not through mashups.
Try to refer https://www.ptc.com/en/support/article/CS312658 and check with EMS
