Dear all ,
i want to upload multiple files from my local machine to the system repository. help me by sharing the thingworx service code
@Sathishkumar_C is correct.
And if you are running a newer version of thingworx, you might want to have a look at the newer file upload widget information.
Here: File Upload Widget
Basically, there is no need for a service as the widget will itself upload the files.
Jens
Make "MultiFilesSelect" property to true in File Upload Widget.
Refer here.. File Upload Widget
Jens
@jensc & @Sathishkumar_C - Through a service call, we want to achieve the file upload functionality not through mashups.
@Hariharasuthan you go with custom extension. that will be a good solution.
