Hello
I switched from TWX 8.2 to 8.5
I have now to use the new composer to work with the platform / mashup, I'm using it since a week about
I see that this is faster, quicker, and some feature are much better managed (expressions, validators... services develop phase with direct save and run...)
However the page style (for me) is more confusing that the old, in particular
May be this is only my personal feeling, and may be on the I'll get used to ...
Is there something that can be changed and depends on some styles ... or no way to change ?
Thank you for your feedback.
I don't know any method to change Composer UI, but I advise you to create a new idea for Thingworx here.
Raluca Edu
Raluca Edu
I posted as a new Idea !
Promote it if you agree ...
Regards
Hi @iguerra.
If you are satisfied with the response provided by Raluca, please mark it as the Accepted Solution for the benefit of others with the same question.
--Sharon
