next scheduler executions / CRON
  • September 19, 2022
  • 2377 views
I need a functionality to determine the next execution date(s) of a scheduler based on it's cron and last execution date (or date range) but I could not find anything useable in Thingworx or Java. Having this capability I could provide an overview of the scheduled task to the End user.
Is there any tool that could help me to achieve this?
Best answer by danmorin
Hi
Manually you can get the last execution date by creating a date time property that will be updated when the scheduler is triggered. That way it will keep the last execution date.
For the next execution date, you can get the cron schedule via service
let table = me.GetConfigurationTable({
tableName: 'Settings' /* STRING */
let result = table.schedule;
and then from the result you can create a function to determine the next execution date
Hope this helps, thanks
danmorin1-VisitorAnswer
Hi
gch13-AquamarineAuthor
Yes it does, but we cannot findout the execution date in the future, for instance for next month?
You need to make the logic by yourself to count the next date. or use this API calls which may help you https://docs.cron-job.org/rest-api.html https://cron-job.org/en/
