not able to select any label text in mashup
NJ_10144761
9-Granite
Hi, I am using Thingworx version 9.2.3-b189, but i am not able to select any label text. I want to copy and paste the text of label in the same mashup. So please let me know who we do that. and also, please let me know is there any custom CSS code for that.
Hello @NJ_10144761,
The issue is have encountered is discussed in the knowledge base article:
Article - CS373340 - Unable to select and copy Label text at runtime in Thingworx
The fix for the issue is available in ThingWorx 9.3.4, In earlier versions the legacy widget is available.
HTH
PEHOWE
2 REPLIES 2
Hello @NJ_10144761,
HTH
PEHOWE
As a workaround: if you start the selection outside of the label you can select it:
