Hello
I am recording data since several weeks but I can only display one or two days of data using a graph and "time picker" widget for start and end date selection.
(I'm using a postgres database)
Is there a limit of history for the data when using value stream to log them? Is it configurable or do I have an issue with my graphs ?
Pascal
We can set the default values by clicking on the Service in the Mashup Builder. It will show the Parameters at the Bottom.
As per my knowledge; there is no inbuilt advanced Service to get average data per Hour. But we have the possibility of writing our own Services and use Query to filter data and also we can use Snippets like average for getting the average as per our requirement etc.
Also, if you are on the latest version of ThingWorx; you can download the new Charts (Charts version 2) from the ThingWorx marketplace. They are more advanced charts and load faster.
I hope it helps.
You should be abe to display data without any time limitations, especially such strict ones as only 2 days.
Value streams only "limitations" are defined as such:
Thanks for this information.
I'm far away from these limits so my problem is probably decribed by Ankit below
Hi pjoly,
Which service are you using to fetch the data from Value Stream? By Default Services fetches 500 Rows. So, you might need to increase the count as per your requirement.
Hello
Thanks for your quick answer and for this information, I guess I'm displaying only 500 items in the graph.
I'm using "QueryPropertyHistory" with StartDate and EndDate from date picker widget.
I can see maxItems in the Parameters of this function, I guess I can increase the number of values with that ? Is there an easy way to fill this query parameter with an higher value (a constant for example) from the mashup builder ?
In order to limit the number of points to display in the graph (already a little bit slow to refresh) , is there advanced services to fetch oldest data such as average values per hours, and after per days, per weeks, etc ...as we can see in some graphical tools ?
Pascal
I hope it helps.
thanks a lot, that's crystal clear.
I'll test the new Chart 2 (I got them)
I have also modified the way to log values to" only when value is changing", this should help a lot as I am measuring luminosity (0% night, almost 100% on sunny day)
