ThingWorx version - 8.2.4
I have created a integration connector with oData connector as base template and able to connect windchill. Using new composer I am able to map the existing endpoints. My question is for some cases we have to access the direct url to query the part information instead of endpoints which doesn't have the option to do. Like in windchill connector there is a method call getbaseurl or getresturl to get the server urls but this method is not available in oData connector. Please assist how to get the server urls instead of hard coding in service.
Hello.
This article seems to imply that the endpoints are integral to using the OData Connector. We'll see if we can find any alternatives that can support the use case you're asking about.
-- Craig A.
