org.hibernate.exception.GenericJDBCException: Could not open connection
ldell'aversano
Hi to everyone,
I've this problem going to Analytics server ( and Builder). I've attached a log file.
The connection test is ok, but when i click to "Data" then appear this error in the log and on popup message: "org.hibernate.exception.GenericJDBCException: Could not open connection".
Someone is my situation?
Help me please!
1 ACCEPTED SOLUTION
cmorfin
(To:cmorfin)
Summary of what has been found offline:
The remaining issue with error "Unexpected exception for job [10]: com.coldlight.dataconnect.transformer.exception.TransformationException: ExecutorLostFailure (executor driver lost)]". was related to the data and not DataConnect configuration.
- 2 features were string features that were not changing over time. It was advise to change these feature as static instead of timed, or to simply remove them from the DAD. See also https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS263713 for details.
- the time sampling interval was set to 10 ms while the data were received at 500ms. Changing the time sampling to 500 ms to match the data, also allowed to reduce the transformation work to be done by DataConnect.
The 2 above points were leading to high memory usage and the termination of the process, hence the error message.
An additional issue came out with error "Failed to create directory within 10000 attempts (tried 1496164223593-0 to 1496164223593-9999)]" due to the deletion of the temp folder of Tomcat. See https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS263805 for details on how to fix.
DataConnect job was successful after those modification
17 REPLIES 17
These are my DataConnect.conf informations:
neuron.base.url=http://localhost:8080/1.0
# This is the URL of the dataconnect server
dataconnect.webservices.url=http://localhost
# This is the base URI of a central file store where to save files uploaded to dataconnect.
dataconnect.transfer.uri=file:///tmp/DataConnect
# These are the AWS access key id and secret key. They are only needed if using S3 as a central file repository
dataconnect.aws.accessKey=
dataconnect.aws.secretKey=
# The following properties are database connection properties
# Dataconnect currently supports the H2 database and PostgresQL
dataconnect.database.driver=org.h2.Driver
dataconnect.database.url=jdbc:h2:/opt/dataconnect/db/dataconnect
dataconnect.database.username=dcuser
dataconnect.database.password=ts
dataconnect.database.type=H2
Hi Luigi
Is this a new ThingWorx Analytics Server VM that you just built or is it something that used to work before ?
From the error you get when selecting DATA in Builder, we seem to have an issue with connecting to the database.
The first thing to check is if the PostgreSQL database has been successfully installed on this VM. ps -ef | grep post should show if some PostgreSQL processes are running or not.
There is currently an issue with the VM packer script that attempt to install an obsolete PostgreSQL version and so the PostgreSQL database ends up not being installed.
The workaround is simply to change the download link and recreate the ThingWorx Analytics Server VM. See https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS256240 for details on that.
Hope this helps
Kind regards
Christophe
Hi Christophe,
I've installed this new Thingworx Analytics Server VM on December 2016, and it worked until yesterday when I've installed and configured Dataconnect.
This is the result of ps -ef command:
For more details see ps(1).
[root@itfioxtdb04 /]# ps -ef
UID        PID  PPID  C STIME TTY          TIME CMD
root         1     0  0 11:59 ?        00:00:02 /usr/lib/systemd/systemd --switc
root         2     0  0 11:59 ?        00:00:00 [kthreadd]
root         3     2  0 11:59 ?        00:00:00 [ksoftirqd/0]
root         5     2  0 11:59 ?        00:00:00 [kworker/0:0H]
root         7     2  0 11:59 ?        00:00:00 [migration/0]
root         8     2  0 11:59 ?        00:00:00 [rcu_bh]
root         9     2  0 11:59 ?        00:00:00 [rcuob/0]
root        10     2  0 11:59 ?        00:00:00 [rcuob/1]
root        11     2  0 11:59 ?        00:00:00 [rcu_sched]
root        12     2  0 11:59 ?        00:00:00 [rcuos/0]
root        13     2  0 11:59 ?        00:00:00 [rcuos/1]
root        14     2  0 11:59 ?        00:00:00 [watchdog/0]
root        15     2  0 11:59 ?        00:00:00 [watchdog/1]
root        16     2  0 11:59 ?        00:00:00 [migration/1]
root        17     2  0 11:59 ?        00:00:00 [ksoftirqd/1]
root        19     2  0 11:59 ?        00:00:00 [kworker/1:0H]
root        20     2  0 11:59 ?        00:00:00 [khelper]
root        21     2  0 11:59 ?        00:00:00 [kdevtmpfs]
root        22     2  0 11:59 ?        00:00:00 [netns]
root        23     2  0 11:59 ?        00:00:00 [perf]
root        24     2  0 11:59 ?        00:00:00 [writeback]
root        25     2  0 11:59 ?        00:00:00 [kintegrityd]
root        26     2  0 11:59 ?        00:00:00 [bioset]
root        27     2  0 11:59 ?        00:00:00 [kblockd]
root        28     2  0 11:59 ?        00:00:00 [md]
root        33     2  0 11:59 ?        00:00:00 [khungtaskd]
root        34     2  0 11:59 ?        00:00:06 [kswapd0]
root        35     2  0 11:59 ?        00:00:00 [ksmd]
root        36     2  0 11:59 ?        00:00:00 [khugepaged]
root        37     2  0 11:59 ?        00:00:00 [fsnotify_mark]
root        38     2  0 11:59 ?        00:00:00 [crypto]
root        46     2  0 11:59 ?        00:00:00 [kthrotld]
root        48     2  0 11:59 ?        00:00:00 [kmpath_rdacd]
root        50     2  0 11:59 ?        00:00:00 [kpsmoused]
root        51     2  0 11:59 ?        00:00:00 [ipv6_addrconf]
root        52     2  0 11:59 ?        00:00:00 [kworker/1:2]
root        71     2  0 11:59 ?        00:00:00 [deferwq]
root       102     2  0 11:59 ?        00:00:00 [kauditd]
root       279     2  0 11:59 ?        00:00:00 [ata_sff]
root       280     2  0 11:59 ?        00:00:00 [scsi_eh_0]
root       281     2  0 11:59 ?        00:00:00 [scsi_tmf_0]
root       282     2  0 11:59 ?        00:00:00 [scsi_eh_1]
root       283     2  0 11:59 ?        00:00:00 [scsi_tmf_1]
root       286     2  0 11:59 ?        00:00:00 [events_power_ef]
root       287     2  0 11:59 ?        00:00:00 [mpt_poll_0]
root       288     2  0 11:59 ?        00:00:00 [mpt/0]
root       291     2  0 11:59 ?        00:00:00 [scsi_eh_2]
root       292     2  0 11:59 ?        00:00:00 [scsi_tmf_2]
root       298     2  0 11:59 ?        00:00:00 [ttm_swap]
root       374     2  0 11:59 ?        00:00:00 [kworker/0:1H]
root       415     2  0 11:59 ?        00:00:00 [kdmflush]
root       416     2  0 11:59 ?        00:00:00 [bioset]
root       427     2  0 11:59 ?        00:00:00 [kdmflush]
root       428     2  0 11:59 ?        00:00:00 [bioset]
root       441     2  0 11:59 ?        00:00:00 [xfsalloc]
root       442     2  0 11:59 ?        00:00:00 [xfs_mru_cache]
root       443     2  0 11:59 ?        00:00:00 [xfs-buf/dm-0]
root       444     2  0 11:59 ?        00:00:00 [xfs-data/dm-0]
root       445     2  0 11:59 ?        00:00:00 [xfs-conv/dm-0]
root       446     2  0 11:59 ?        00:00:00 [xfs-cil/dm-0]
root       447     2  0 11:59 ?        00:00:00 [xfs-reclaim/dm-]
root       448     2  0 11:59 ?        00:00:00 [xfs-log/dm-0]
root       449     2  0 11:59 ?        00:00:00 [xfs-eofblocks/d]
root       450     2  0 11:59 ?        00:00:00 [xfsaild/dm-0]
root       529     1  0 11:59 ?        00:00:01 /usr/lib/systemd/systemd-journal
root       551     1  0 11:59 ?        00:00:00 /usr/sbin/lvmetad -f
root       552     2  0 11:59 ?        00:00:00 [rpciod]
root       566     1  0 11:59 ?        00:00:00 /usr/lib/systemd/systemd-udevd
root       607     2  0 11:59 ?        00:00:00 [xfs-buf/sda1]
root       608     2  0 11:59 ?        00:00:00 [xfs-data/sda1]
root       609     2  0 11:59 ?        00:00:00 [xfs-conv/sda1]
root       610     2  0 11:59 ?        00:00:00 [xfs-cil/sda1]
root       611     2  0 11:59 ?        00:00:00 [xfs-reclaim/sda]
root       612     2  0 11:59 ?        00:00:00 [xfs-log/sda1]
root       613     2  0 11:59 ?        00:00:00 [xfs-eofblocks/s]
root       614     2  0 11:59 ?        00:00:00 [xfsaild/sda1]
root       654     2  0 11:59 ?        00:00:00 [kdmflush]
root       655     2  0 11:59 ?        00:00:00 [bioset]
root       665     2  0 11:59 ?        00:00:00 [xfs-buf/dm-2]
root       666     2  0 11:59 ?        00:00:00 [xfs-data/dm-2]
root       667     2  0 11:59 ?        00:00:00 [xfs-conv/dm-2]
root       668     2  0 11:59 ?        00:00:00 [xfs-cil/dm-2]
root       669     2  0 11:59 ?        00:00:00 [xfs-reclaim/dm-]
root       670     2  0 11:59 ?        00:00:00 [xfs-log/dm-2]
root       671     2  0 11:59 ?        00:00:00 [xfs-eofblocks/d]
root       672     2  0 11:59 ?        00:00:00 [xfsaild/dm-2]
root       696     1  0 11:59 ?        00:00:00 /sbin/auditd -n
root       712   696  0 11:59 ?        00:00:00 /sbin/audispd
root       717   712  0 11:59 ?        00:00:00 /usr/sbin/sedispatch
root       720     1  0 11:59 ?        00:00:00 /usr/sbin/alsactl -s -n 19 -c -E
dbus       722     1  0 11:59 ?        00:00:00 /bin/dbus-daemon --system --addr
root       725     1  0 11:59 ?        00:00:00 /usr/sbin/ModemManager
rtkit      726     1  0 11:59 ?        00:00:00 /usr/libexec/rtkit-daemon
root       727     1  0 11:59 ?        00:00:00 /usr/sbin/rsyslogd -n
libstor+   729     1  0 11:59 ?        00:00:00 /usr/bin/lsmd -d
root       730     1  0 11:59 ?        00:00:00 /usr/libexec/accounts-daemon
root       732     1  0 11:59 ?        00:00:00 /usr/sbin/abrtd -d -s
root       736     1  0 11:59 ?        00:00:00 /usr/sbin/smartd -n -q never
root       737     1  0 11:59 ?        00:00:00 /usr/bin/abrt-watch-log -F Backt
root       739     1  0 11:59 ?        00:00:00 /usr/sbin/irqbalance --foregroun
chrony     742     1  0 11:59 ?        00:00:00 /usr/sbin/chronyd
root       743     1  0 11:59 ?        00:00:01 /usr/bin/vmtoolsd
root       744     1  0 11:59 ?        00:00:02 /sbin/rngd -f
avahi      745     1  0 11:59 ?        00:00:00 avahi-daemon: running [itfioxtdb
root       748     1  0 11:59 ?        00:00:00 /usr/lib/systemd/systemd-logind
root       749     1  0 11:59 ?        00:00:00 /usr/bin/abrt-watch-log -F BUG:
root       757     1  0 11:59 ?        00:00:00 /usr/sbin/NetworkManager --no-da
avahi      762   745  0 11:59 ?        00:00:00 avahi-daemon: chroot helper
root       764     1  0 11:59 ?        00:00:00 /bin/bash /usr/sbin/ksmtuned
root       783     1  0 11:59 ?        00:00:00 /usr/sbin/gssproxy -D
polkitd    789     1  0 11:59 ?        00:00:02 /usr/lib/polkit-1/polkitd --no-d
root       815     1  0 11:59 ?        00:00:00 /usr/sbin/wpa_supplicant -u -f /
zookeep+  1079     1  0 11:59 ?        00:00:01 /usr/bin/java -cp /opt/zookeeper
tomcat    1085     1 99 11:59 ?        00:21:42 /usr/lib/jvm/jre/bin/java -Xmx10
root      1086     1  0 11:59 ?        00:00:00 /usr/bin/python -Es /usr/sbin/tu
root      1093     1  0 11:59 ?        00:00:00 /usr/sbin/sshd -D
root      1102     1  0 11:59 ?        00:00:00 /usr/sbin/cupsd -f
root      1105     1  0 11:59 ?        00:00:00 /usr/sbin/xrdp-sesman --nodaemon
root      1106     1  0 11:59 ?        00:00:00 /usr/sbin/xrdp --nodaemon
root      1112     1  0 11:59 ?        00:00:00 /usr/sbin/libvirtd
root      1122     1  0 11:59 ?        00:00:00 /usr/sbin/atd -f
root      1123     1  0 11:59 ?        00:00:00 /usr/sbin/crond -n
root      1125     1  0 11:59 ?        00:00:00 /usr/sbin/gdm
postgres  1200     1  0 11:59 ?        00:00:00 /usr/pgsql-9.4/bin/postgres -D /
root      1256  1125  0 11:59 tty1     00:00:00 /usr/bin/Xorg :0 -background non
postgres  1441  1200  0 11:59 ?        00:00:00 postgres: logger process
postgres  1487  1200  0 11:59 ?        00:00:00 postgres: checkpointer process
postgres  1488  1200  0 11:59 ?        00:00:00 postgres: writer process
postgres  1489  1200  0 11:59 ?        00:00:00 postgres: wal writer process
postgres  1490  1200  0 11:59 ?        00:00:00 postgres: autovacuum launcher pr
postgres  1491  1200  0 11:59 ?        00:00:00 postgres: stats collector proces
root      1764     1  0 11:59 ?        00:00:00 /usr/libexec/postfix/master -w
postfix   1782  1764  0 11:59 ?        00:00:00 qmgr -l -t unix -u
root      2435  1125  0 11:59 ?        00:00:00 gdm-session-worker [pam/gdm-laun
nobody    2481     1  0 11:59 ?        00:00:00 /sbin/dnsmasq --conf-file=/var/l
root      2483  2481  0 11:59 ?        00:00:00 /sbin/dnsmasq --conf-file=/var/l
gdm       2512  2435  0 11:59 ?        00:00:00 /usr/bin/gnome-session --autosta
gdm       2515     1  0 11:59 ?        00:00:00 /usr/bin/dbus-launch --exit-with
gdm       2520     1  0 11:59 ?        00:00:00 /bin/dbus-daemon --fork --print-
gdm       2529     1  0 11:59 ?        00:00:00 /usr/libexec/at-spi-bus-launcher
root      2530     1  0 11:59 ?        00:00:05 /bin/java -Dwrapper.pidfile=/run
gdm       2538  2529  0 11:59 ?        00:00:00 /bin/dbus-daemon --config-file=/
gdm       2544     1  0 11:59 ?        00:00:00 /usr/libexec/at-spi2-registryd -
gdm       2561  2512  0 11:59 ?        00:00:00 /usr/libexec/gnome-settings-daem
root      2568     1  0 11:59 ?        00:00:00 /usr/libexec/upowerd
gdm       2572     1  0 11:59 ?        00:00:00 /usr/libexec/gvfsd
gdm       2576     1  0 11:59 ?        00:00:00 /usr/libexec/gvfsd-fuse /run/use
root      2597  2530  0 11:59 ?        00:00:06 /bin/java -classpath /opt/yajsw/
gdm       2624  2512  0 11:59 ?        00:00:03 gnome-shell --mode=gdm
colord    2628     1  0 11:59 ?        00:00:00 /usr/libexec/colord
gdm       2641     1  0 11:59 ?        00:00:00 /usr/bin/pulseaudio --start --lo
gdm       2659     1  0 11:59 ?        00:00:00 /usr/libexec/dconf-service
gdm       2668  2624  0 11:59 ?        00:00:00 ibus-daemon --xim --panel disabl
gdm       2673  2668  0 11:59 ?        00:00:00 /usr/libexec/ibus-dconf
gdm       2675     1  0 11:59 ?        00:00:00 /usr/libexec/ibus-x11 --kill-dae
gdm       2682     1  0 11:59 ?        00:00:00 /usr/libexec/mission-control-5
gdm       2684     1  0 11:59 ?        00:00:00 /usr/libexec/caribou
root      2687     1  0 11:59 ?        00:00:00 /usr/libexec/packagekitd
gdm       2698     1  0 11:59 ?        00:00:00 /usr/libexec/goa-daemon
gdm       2712     1  0 11:59 ?        00:00:00 /usr/libexec/gvfs-udisks2-volume
root      2724     1  0 11:59 ?        00:00:00 /usr/lib/udisks2/udisksd --no-de
gdm       2730     1  0 11:59 ?        00:00:00 /usr/libexec/goa-identity-servic
gdm       2750     1  0 11:59 ?        00:00:00 /usr/libexec/gvfs-gphoto2-volume
gdm       2754     1  0 11:59 ?        00:00:00 /usr/libexec/gvfs-mtp-volume-mon
gdm       2758     1  0 11:59 ?        00:00:00 /usr/libexec/gvfs-afc-volume-mon
gdm       2763     1  0 11:59 ?        00:00:00 /usr/libexec/gvfs-goa-volume-mon
gdm       2788  2668  0 11:59 ?        00:00:00 /usr/libexec/ibus-engine-simple
postgres  2848  1200  0 12:00 ?        00:00:00 postgres: neuronuser neuronuser
postgres  2849  1200  0 12:00 ?        00:00:00 postgres: neuronuser neuronuser
postgres  2850  1200  0 12:00 ?        00:00:00 postgres: neuronuser neuronuser
postgres  2851  1200  0 12:00 ?        00:00:00 postgres: neuronuser neuronuser
postgres  2852  1200  0 12:00 ?        00:00:00 postgres: neuronuser neuronuser
postgres  2853  1200  0 12:00 ?        00:00:00 postgres: neuronuser neuronuser
postgres  2854  1200  0 12:00 ?        00:00:00 postgres: neuronuser neuronuser
postgres  2855  1200  0 12:00 ?        00:00:00 postgres: neuronuser neuronuser
postgres  2856  1200  0 12:00 ?        00:00:00 postgres: neuronuser neuronuser
postgres  2857  1200  0 12:00 ?        00:00:00 postgres: neuronuser neuronuser
postfix   3597  1764  0 12:00 ?        00:00:00 pickup -l -t unix -u
root      3604  1106  0 12:00 ?        00:00:08 /usr/sbin/xrdp --nodaemon
root      3605     2  0 12:00 ?        00:00:00 [kworker/1:2H]
root      3690  1105  0 12:01 ?        00:00:00 /usr/sbin/xrdp-sessvc 3692 3691
root      3691  3690  0 12:01 ?        00:00:00 /usr/sbin/xrdp-sesman --nodaemon
root      3692  3690  7 12:01 ?        00:01:17 Xvnc :10 -geometry 1280x773 -dep
root      3695  3691  0 12:01 ?        00:00:00 /bin/gnome-session --session=gno
root      3710  3690  0 12:01 ?        00:00:00 xrdp-chansrv
root      3799     1  0 12:01 ?        00:00:00 dbus-launch --sh-syntax --exit-w
root      3800     1  0 12:01 ?        00:00:00 /bin/dbus-daemon --fork --print-
root      3867     1  0 12:01 ?        00:00:00 /usr/libexec/imsettings-daemon
root      3870     1  0 12:01 ?        00:00:00 /usr/libexec/gvfsd
root      3874     1  0 12:01 ?        00:00:00 /usr/libexec/gvfsd-fuse /run/use
root      3926  3695  0 12:01 ?        00:00:00 /usr/bin/ssh-agent /etc/X11/xini
root      3931     1  0 12:01 ?        00:00:00 /usr/libexec/at-spi-bus-launcher
root      3935  3931  0 12:01 ?        00:00:01 /bin/dbus-daemon --config-file=/
root      3939     1  0 12:01 ?        00:00:00 /usr/libexec/at-spi2-registryd -
root      3954  3695  0 12:01 ?        00:00:00 /usr/libexec/gnome-settings-daem
root      3962     1  0 12:01 ?        00:00:00 /usr/bin/gnome-keyring-daemon --
root      3973     1  0 12:01 ?        00:00:00 /usr/bin/pulseaudio --start
root      3983  3695 27 12:01 ?        00:04:45 /usr/bin/gnome-shell
root      3999     1  0 12:01 ?        00:00:00 /usr/libexec/gsd-printer
root      4007  3983  0 12:01 ?        00:00:00 ibus-daemon --xim --panel disabl
root      4012  4007  0 12:01 ?        00:00:00 /usr/libexec/ibus-dconf
root      4014     1  0 12:01 ?        00:00:00 /usr/libexec/ibus-x11 --kill-dae
root      4016     1  0 12:01 ?        00:00:00 /usr/libexec/gnome-shell-calenda
root      4025     1  0 12:01 ?        00:00:00 /usr/libexec/mission-control-5
root      4029     1  0 12:01 ?        00:00:01 /usr/libexec/caribou
root      4032     1  0 12:01 ?        00:00:00 /usr/libexec/evolution-source-re
root      4034     1  0 12:01 ?        00:00:00 /usr/libexec/dconf-service
root      4043     1  0 12:01 ?        00:00:00 /usr/libexec/goa-daemon
root      4061     1  0 12:01 ?        00:00:00 /usr/libexec/gvfs-udisks2-volume
root      4076     1  0 12:01 ?        00:00:00 /usr/libexec/gvfs-gphoto2-volume
root      4090     1  0 12:01 ?        00:00:00 /usr/libexec/gvfs-mtp-volume-mon
root      4104     1  0 12:01 ?        00:00:00 /usr/libexec/goa-identity-servic
root      4106     1  0 12:01 ?        00:00:00 /usr/libexec/gvfs-afc-volume-mon
root      4121     1  0 12:01 ?        00:00:00 /usr/libexec/gvfs-goa-volume-mon
root      4133  3695  1 12:01 ?        00:00:12 nautilus --no-default-window --f
root      4138  3695  0 12:01 ?        00:00:00 abrt-applet
root      4139  3695  0 12:01 ?        00:00:00 /usr/bin/gnome-software --gappli
root      4140  3695  0 12:01 ?        00:00:00 /usr/bin/seapplet
root      4142     1  0 12:01 ?        00:00:01 /usr/bin/vmtoolsd -n vmusr
root      4148  3695  0 12:01 ?        00:00:00 /usr/libexec/tracker-extract
root      4150  3695  0 12:01 ?        00:00:00 /usr/libexec/tracker-miner-apps
root      4153  3695  0 12:01 ?        00:00:00 /usr/libexec/tracker-miner-fs
root      4157  3695  0 12:01 ?        00:00:00 /usr/libexec/tracker-miner-user-
root      4177     1  0 12:01 ?        00:00:00 /usr/libexec/tracker-store
root      4242     1  0 12:01 ?        00:00:00 /usr/libexec/gconfd-2
root      4247     1  0 12:01 ?        00:00:00 /usr/libexec/gvfsd-trash --spawn
root      4259     1  0 12:01 ?        00:00:00 /usr/libexec/evolution-calendar-
root      4267  4007  0 12:01 ?        00:00:00 /usr/libexec/ibus-engine-simple
root      4270     1  0 12:01 ?        00:00:00 /usr/libexec/gvfsd-metadata
root      4425     1  0 12:02 ?        00:00:00 /usr/libexec/gnome-terminal-serv
root      4428  4425  0 12:02 ?        00:00:00 gnome-pty-helper
root      4429  4425  0 12:02 pts/0    00:00:00 /bin/bash
root      4561     2  0 12:02 ?        00:00:00 [kworker/0:3]
root      4686  3983  5 12:05 ?        00:00:41 /usr/lib64/firefox/firefox
root      4794     2  0 12:06 ?        00:00:00 [kworker/u4:2]
root      4842     2  0 12:07 ?        00:00:00 [kworker/1:1]
root      5064     1  0 12:10 ?        00:00:00 /usr/bin/gedit --gapplication-se
root      5079     2  0 12:11 ?        00:00:00 [kworker/u4:1]
root      5114     2  0 12:12 ?        00:00:00 [kworker/0:0]
root      5209  4425  0 12:17 pts/1    00:00:00 /bin/bash
root      5221     1  0 12:17 ?        00:00:00 /usr/sbin/abrt-dbus -t133
root      5255     2  0 12:17 ?        00:00:00 [kworker/0:1]
root      5264   764  0 12:18 ?        00:00:00 sleep 60
root      5266  5209  0 12:18 pts/1    00:00:00 ps -ef
Do you note some issues?
On March I've already configured a Dataconnect with success (Re: Thingworx Analytics: Send Data From Dataconnect To Analytics Server) but now I don't Know what are happening.
I'm waiting your feedback.
Thank's
Luigi
Hi Christophe,
I've done "sudo reboot -h now" and analytics builder now is running without exceptions popup!
The problem now is on dataconnect, I have these log informations:
- Received error from DataConnect for job status: DataSetName: [Tractor_DAD] - [500 - Internal Server Error: Unexpected Error. Please contact support.].
- No File Repository found in Configuration for [Tractor_DAD]. Falling back to default - [SystemRepository]
- Failed to submit to DataConnect: {"headers":{"Content-type":"application/json","Accept":"application/json","neuron-application-key":"1","neuron-application-id":"neuronuser"},"errorMessage":"Unexpected Error. Please contact support.","errorId":"6f4cad3e-fdb6-4106-9294-600aa3365062","responseStatus":{"reasonPhrase":"Internal Server Error","protocolVersion":{"protocol":"HTTP","major":1,"minor":1},"statusCode":500}}
- Error while processing task : Failed to submit to DataConnect: DataConnect was unable to process request.
- Task-1495533576377 Data Analysis Task Failed. Please check the logs for errors
- Task-1495533576377 Data Analysis Task In Error.
Do you Know what is the problem now?
Waiting your feedback,
thank's
Luigi
Hi Luigi
Did you install DataConnect on the same VM as ThingWorx Analytics Server ?
As you mentioned, back in March you configure a system with DataConnect, is it a different one here or is it the same ?
Could you send the followign log:
- /opt/dataconnect/logs
-<tomcat>/logs
Thank you
Kind regards
Christophe
Hi Christophe,
I've installed (like in March, but it was another project) on the same VM, Thingworx Analytics Server and Dataconnect.
The configuration is the same like March project (dataconnect.conf for example).
I attach the log and hope you find a mistake.
Thank's
Luigi
Hi Luigi
The error message we get is
Caused by: org.h2.jdbc.JdbcSQLException: Wrong user name or password [28000-190]
so when attempting to connect to the H2 DataConnect database the username and password is not ok.
Thsi is created at runtime, but it is posible that during a previous start the dataconnect database got created with a different credentials not accepted anymore.
Could you try to modify /opt/dataconnect/config/dataconnect.conf and change
to
dataconnect.database.url=jdbc:h2:/opt/dataconnect/db/dataconnect2
then restart Tomcat and try again ?
If you still have issue, please send the dataconnect.conf in addition to the dataconnect.log and Tomcat log files.
Note though that it is recommended to have ThingWorx Analytics and DataConnect on 2 different machine (see DataConnect Guide, page 8, Requirements)
Kind regards
Christophe
Hi Christophe,
now, after changing
to
I've a new status for Dataconnect Tractor_DAD, from "not found" to "Queue".
I've attached the required files.
Now I've a doubt that dataconnect.conf isn't the last version of last project, Could you check it.
I Know that is recommended to have ThingWorx Analytics and DataConnect on 2 different machine (see DataConnect Guide, page 8, Requirements), but for project in march we had no issues.
Thank's
Luigi
Hi Luigi
The DataConnect log file you attached are the same as earlier on, so I do not have the entries for when the job is queued.
I notice somethign incorrect though in your dataconnect.conf file
you have got
neuron.base.url=http://localhost:8080/twxml-connect/1.0
it should be
neuron.base.url is the uri to ThingWorx Analytics Server, twxml-connect is the DataConnect webapp.
So you can change this, then restart Tomcat.
If still issue send again ll the latest log and conf files.
Thank you
Christophe
Hi Christophe,
I've corrected dataconnect.conf and there are improvements but still mistakes.
I attach the ultimate log of dataconnect, tomcat and dataconnect.conf.
Now, this is the scenario: I've created a DAD for our analysis, and dataconnect creates a zip file with all csv skinny file that need to Analytics.
But, after a lot of hours of "running state" (6 hours approximately), i've got a mistake that I don't understood : "Unexpected exception for job [10]: com.coldlight.dataconnect.transformer.exception.TransformationException: ExecutorLostFailure (executor driver lost)]".
To complete the informations, I attach a DAD configuration screenshot.
Could you help me again?
Thank's
Luigi
Hi Luigi
A few points here:
- I see that you changed DAD, did you confirm that all works ok with the Tractor_DAD ?
Before moving to your own one, I would rather stick to this Tractor (I assume this is the one from How to use DataConnect when sending property values from the ThingWorx platform to ThingWorx Analytics.) as I know it works.
Once we confirm it works for this one, we will be sure of the DataConnect configuration and then can move to your own DAD.
From the log I don't seem to see a successful Tractor_DAD. DataConnect complains of empty csv file. It is possible that the properties did not get populated so no data were available. The above blog provides a little simulator that allows to populate data - or you can also populate some manually.
- I also see some errors on null timeSamplingInterval, so make sure the time sampling interval is set in the DAD General tab
- I also see some error on empty csv file for your DAD, so here again it might be because of lack of value for the properties, or it can be something else this is why making sure it works with Tractor will help.
- you wrote the zip is created with skinny csv files in it. do you see some data in those csv file ? Could you attach the zip file ?
Thank you
Christophe
Hi Christophe,
I've tested Tractor-DAD example and it works fine.
Now I don't know why other DAD doesn't work.
I attach a zip of skinny files.
Luigi
Hi Luigi
Could you please send also the payload.json file that is present in the same directory as the csv zip file ?
I'd like to make a few tests, to confirm the issue I can see with the data in csv files
Thank you
Kind regards
Christophe
This is the Payload.json create by Dataconnect.
Luigi
Hy do you have any news related?
cmorfin
(To:mpagliotta)
Hi Marco
I have taken this offline with Luigi
Will update the threads when we get to the bottom of it
Kind regards
Christophe
cmorfin
(To:cmorfin)
