Its really confusing, why parseInt('08') is giving NaN?
parseInt('010') is 8?
parseInt('0101') is 65?
Is it working on the basis of Binary?
but in JS it is working correctly.
Clarify Please,
Janakiraman P
You are correct, the JAR is named custom-rhino-js-5.1.0.jar in your version of ThingWorx.
It is apparently based on rhino 1.7R4 (as per MANIFEST.MF). This version is from 2012, it apparently complies to ECMAScript 3 + JavaScript 1.7 and some regex feature from JavaScript 1.8.
Stéphane
Hi Janakiraman
See also https://stackoverflow.com/questions/850341/how-do-i-work-around-javascripts-parseint-octal-behavior
-- sma
I understood the problem.
in JavaScript it is working fine.
parseInt(string, radix);
If the input string
begins with "0"
(a zero), radix is assumed to be 8 (octal) or 10 (decimal). Exactly which radix is chosen is implementation-dependent. ECMAScript 5 clarifies that 10 (decimal) should be used, but not all browsers support this yet. For this reason always specify a radix when using parseInt
But the problem has been resolved in ECMAScript 5.
Is Thingworx using ECMAScript 3 ?
Janakiraman P
Rhino is used as Javascript engine for ThingWorx Service.
To identify the version of Rhino used in your version of ThingWorx, look a the rhino JAR filename in <Tomcat>\webapps\Thingworx\WEB-INF\lib\
The specified JAR is not available at <Tomcat>\webapps\Thingworx\WEB-INF\lib\
Am using Thingworx 8.4.2. Not sure which version of JavaScript is used.
regards,
Janakiraman P
Stéphane
Okay, Thanks for your solution.
The error (NaN) because of ECMAScript 3, so here
radix is Octal by default in Thingworx.
Janakiraman P
