project import in 9.2
AP_9587236
In 9.2, importing project's entities adding to default project if we didnt created the project name first. What is the solution for this?
Hi @AP_9587236,
If you navigate to Import/Export from the left navigation bar, export collections of entities and specify project, you should be able export all entities with matching project.
Then import the entity, the project will be created automatically even the project was not there in the system.
Tony
No this is not working. We have to create project name first before importing. If not project name won be created. All entities will be added in default project.
Hi @AP_9587236,
If you feel your question has been answered, please mark the appropriate response as the Accepted Solution for the benefit of others with the same question.
Tony
Tony
