"Entity Import Not Supported for File Type: .zip" when trying to import an extension
Raccone
Hello everyone,
I am trying to import an extension, and I keep getting the error I wrote down in the Subject:
this happens with any extension, also the one build in this tutorial. The only thing I have done differently is the Gradle build, which I carried out via Command Prompt, but the error shows up also if I use the pre-built .zip file in the tutorial files.
I am using a 30-day cloud trial now, so I wonder if this could be a limitation of the trial.
Thanks and best regards!
jman87
(To:Raccone)
Are you importing this specifically as extension import or just "file import"? Please make sure to use "Extension Import" .
Best Wishes!
Teresa
5 REPLIES 5
jman87
(To:Raccone)
Best Wishes!
Teresa
Raccone
(To:jman87)
Hi @jman87 ,
This definitely was the issue, the thing being that I got confused by the second window, erroneously selecting "From File" because I thought it meant "Import extension from file".
Thanks for the help,
Federico
Hello @Raccone
follow this steps:
BR,
Max
Raccone
(To:Rocket_Max)
Hi @Rocket_Max,
Thanks for the answer. I'm going to accept @jman87's answer just because it came first chronologically.
Federico
@Raccone This is just a supplement to @jman87 ’s description. Welcome to "PTC Community".
BR,
Max
