"Executing a service by passing name of the service as a parameter
amittal1
HI,
In Thingworx is there a way by which I can execute a service, through passing the name of the service as parameter from another service?
To be more clear, consider the following snippet --
I have two services in a thing 'Thing_Example' as 'srvA' and 'srvB'
Defination of 'srvA' --
Inputs: serviceName; Type: String; Value: 'srvB'
Service body --
var result = Things["Thing_Example"][serviceName];  //At this point I am expecting that
                                                   'srvB' should be executed
Thanks and Regards
Aditya Mittal
Ashritha
(To:amittal1)
Use following code snippet to call service dynamically
var serviceName = "test1";
result=Things[thingName][serviceName]();
9 REPLIES 9
anarwal
(To:amittal1)
Hi @amittal1 , You can call another service result on the same service . what difficulty you are facing?
I understand that the output of one service can be called on another one.
But my requirement is different. We can call a service only if we know the name of the service. But in my case the name of the service is coming as a parameter. If you see my requirement in snippet that I provided, you will understand.
Please let me know if something is not clear.
Aditya
anarwal
(To:amittal1)
@amittal1 , It will not be possible because Things["ThingName"].var where var is an argument will not be understood.
Ok..I thought so !!!
but for properties it is possible to have similar mechanism like--
var propname = prop1;
result = Things['ThingName'].prop1;  //OPTION 1; if you know the name of property
result = Things['ThingName'][propname];  //OPTION 2; If property name is coming via
                                           service parameter
I thought maybe there is some way or 'trick' by which I can achieve my requirement.
Ashritha
(To:amittal1)
Make use of ContentLoaderFunctions and change the name of the service in the input url .
slangley
23-Emerald II
(To:amittal1)
Hi @amittal1.
If you feel your question has been answered, please mark the appropriate response as the Accepted Solution for the benefit of others with the same question.
--Sharon
I was still waiting for some comments after my last post, where I mentioned that for properties there is a way you can access them using a parametrized way. I was hoping there would be some way of executing services also.
-Aditya
Ashritha
(To:amittal1)
slangley
23-Emerald II
(To:slangley)
Hi @amittal1.
Do you have further questions on this post?  If not, please mark the appropriate response as the Accepted Solution for the benefit of others with the same question.
--Sharon
