"Failed to dispatch event" if I use "Automatically update values when able", follow up discussion
bbeuckSIG
Hello everyone,
this is a follow up to this and that post as there was no solution suggested. The related support article suggests to turn off the feature as a "workaround".
As I am currently working on Thingworx 8.4.4 I am afraid the only option I have is to upgrade to 9.x? Can someone report if the issue is resolved in the latest releases?
Thank you
Benny
mnarang
(To:bbeuckSIG)
I have tested this in ThingWorx 9.1 and this is not reproducible now. There is no error while you use this feature now.
mnarang
(To:bbeuckSIG)
slangley
(To:bbeuckSIG)
Hi @bbeuckSIG
Since it appears your question has been answered, please mark the previous response as the Accepted Solution for the benefit of others with the same question.
--Sharon
I did accept the reply as a solution. But it only answers half of my question. Granted, I did not phrase my questions well, so I am clearer now:
I cannot easily upgrade to Release 9, is there anything I can do in Release 8.4.4. to use this feature without getting those error messages?
mnarang
(To:bbeuckSIG)
There has been a lot of work done to improve this kind of error in ThingWorx 9.x. Moreover, I believe 8.4 standard support has been ended so there is no way to use this feature without getting these error messages. I understand these are errors in application logs, but I think this is not hindering functionality in your use case.
Thank you @mnarang .
Technically you are right, everything is still working as intended. But the Application Log becomes useless as I cannot see any other error than this one. An expensive trade off, not sure what I am going to do.
Anyways, my question is fully answered now, thank you.
