Suddenly, there was a "!" next to the service
And it is not executed.
When I execute error message is "Error executing service. Message ::Unable To Convert From org.mozilla.javascript.UniqueTag to INFOTABLE - See Script Error Log for more details."
Why did this happen?
somebody help me
Hi ,
This is because you might have created duplicate of the existing generic service . Duplicate generic services shows (!) in front of them . For the error you might have selected Output base type as Infotable but service might not be returning any infotable . You may need to select correct output type of service which your service is returning.
Hi ,
oh thank you.
I solved the problem thanks to your help.
