I have created a responsive mashup(second layout).
I created the mashup using 1024 x 768
The problem appears when i try to open the same responsive mashup in a screen with a different resolution (1366 x 768).
In that case,the contents of the screen becomes left aligned and a lot of white space appears on the right side of the screen .
Please suggest a solution to the above mentioned problem.
Thanks and regards,
Saurabh
Can someone please advise in this case .. THanks
