hi community,
how can I retrieve names of all things, thingtemplates, datashape, ..... in thingworx
Thanks in advance.
Anass nasser
You can execute GetEntities service on the Project to get the list of all Things , ThingTemplates and DataShapes covered in that project.
You can retrieve the list of Things , ThingTemplates and dataShapes by making the rest call on the desired endpoints.
For example,
If you would like to get all your Things , then you can make below rest call
https://localhost:8443/Thingworx/Things where localhost is your host name and 8443 is the port on which Thingworx is deployed
For getting List of ThingTemplates, you can make below rest call
https://localhost:8443/Thingworx/ThingTemplates
first of all thank you,
my question is there is any service or a function to retrieve all things, template,propeties,... inside a project, i want to make a copy of all entities in thingworx, to be able to give permessions by using a csv file.
Thank you in advance.
