sequence between data table and label chart widget
xiaoqw
Here is a question: when I insert data inside data table entities and want to show this data using label chart. May I know what is the sequence for label chart displaying the data. Because here is out of sequence and I struggling with this question!!!
slangley
(To:xiaoqw)
Hi @xiaoqw.
Unfortunately, we're unable to see the image you attached and we're not clear on the issue you are having.  Can you please provide some clarification--possibly an example?  Also, if you can reattach your image, it would be helpful.  You'll need to click the Photos button to do so.
Regards.
--Sharon
xiaoqw
(To:slangley)
hi, @slangley here is the sequence in data table. chart.pngcolumn.pnghere is label chart
slangley
(To:slangley)
Hi @xiaoqw.
From the screenshot it appears that only July 2019 is out of order--though some columns are not labelled so that is an assumption.
Which version of ThingWorx are you running?  In terms of the records from the data table you're showing in the screenshot, do you know for sure this is the order it's actually stored in the data table?  Are you applying any sort?  Can you send us an export of the data table so we can test it?
Regards.
--Sharon
