split image into rows and columns
schakravarthy
6-Contributor
Hi ,
i want to split one single image into rows and columns (PLEASE REFER THE IMAGE ATTACHED). is it possible to do that , if so how ?
You would have to use custom logic as this is not an out-of-the-box functionality. You may try with css or look up variations of javascript services to do so https://stackoverflow.com/questions/8912917/cutting-an-image-into-pieces-through-javascript
