I have created the style theme and linked in the mashup in Thingworx 8.4.
Kindly Let me know what are the steps next to do
Hi @mervinnobelraj.
It appears you're using the legacy button widget. This one is not theme-able.
Try it with the new button widget and you should be able to set the Button Type.
Regards.
--Sharon
I'm still new to the subject of themes but some widgets have a "Use Theme"-Property. Maybe you forgot to set this true.
Thanks , But
It is not working on the labels
How to define a button as Primary or Secondary through Style theme in a Mashup
Hi @mervinnobelraj.
Please provide more information regarding what you expect to achieve. Screenshots would be helpful.
Regards.
--Sharon
Hi @slangley ,
Here i have attached sample screen shot of creating the style theme and applying the style theme in the mashup but it is not working in the button widget
Hi @mervinnobelraj.
Regards.
--Sharon
Hello @mervinnobelraj
If your query is answered , please mark the appropriate response as resolved for benefit of others with same questions.
Om dukiya
