Is it possible to write a subscription to monitor a folder in C drive or any local drive?
Eg: I have a folder in C drive inside which there is no file. If there I put any file inside that folder my subscription should work and trigger another service in my ThingWorx. Or if I make any changes to the file in that folder and save it, I want my subscription to get triggered.
I know I can trigger a data change in kepware using subscription but is it possible to do it using local drive?
Please provide me some help
V Shalini.
Out of the box not, but You can use the Edge SDK or the Edge Microserver to build a service which keeps track of the folder and throws a remove event accordingly then with the FileTransfer features on ThingWorx you can upload this file to the platform.
If you are satisfied with the response provided by Carles, please mark it as the Accepted Solution for the benefit of others who may have the same question.
--Sharon
