the "IP WhiteList" in Application Keys didn't work. For example,I enter "192.168.234.123" in IP WhiteList field,but I can still access the Thingworx server through another computer.(192.168.12.11) and this appkey.
The IP WhiteList didn't work!
How can I fix it?
Thanks in advance.
hyman.
This seems a bug, better you open a case on eSupport portal.
Carles.
Thanks for answering.
Since It's not urgent, so I want to study it first.
Hi, which SDK are you using? Just for your info there is an existing enhancement request for this issue as it appears to be currently applied only on REST interface and not to the websocket communications, see this article
Thank you ! But Is there any way to make it available for SDKs?
What ThingWorx version are you using and what SDK?
Meghan
Thank you. The version is 7.0 and we use Java SDK.
hyman
