i am trying to run the sample code provided in the thingworx android sdk
I have a problem in every sample project
it says cant resolve the constructor
thing = new VirtualThing(thingName, "A basic virtual thing", client);
because the client is not initiialized
similarly
client.isConnected() is also showing error
i dont know what 'client' is because the variable is also not declared anywhere.
kindly tell the solution
Hi Dibya, it seems to me that your project is not correctly setup in studio, here's the blog you could use to correct it Exploring ThingWorx Android SDK together with web based Revision Control System and secured connection to ThingWorx Serv…
Hi dibya ranjan mishra,
Have you added the ThingWorx Android SDK jars to your project?
yes i have added. I just had to import the sample project in the android studio
Could you just run the exampleconnection project and check if it is working or not
From where have you downloaded this project? Could you share the link?
BTW are you executing this project on Win 10?
sir
actually i corrected that error
it was importing some AndroidConnectedThingClient
but I guess thingworx has changed it to ConnectedThingClient
because i extracted all the 2 jar files I could not find AndroidConnectedThingClient.class
Its better if you could see the sample codes and change it to ConncetedThingClient
https://developer.thingworx.com/resources/guides/thingworx-android-sdk-setup-guide
i got the android sdk from here and then trying to run the ExampleConnection project present in the samples folder of android sdk
package com.thingworx.ptc.shell.utilities;
import android.app.Service;
import android.content.BroadcastReceiver;
import android.content.Context;
import android.content.Intent;
import android.content.IntentFilter;
import android.os.Bundle;
import android.os.Handler;
import android.os.HandlerThread;
import android.os.IBinder;
import android.os.Looper;
import android.os.Message;
import android.os.Process;
import android.support.annotation.Nullable;
import android.util.Log;
<---------this is the error I am saying about-------------------------------->
import com.thingworx.communications.client.AndroidConnectedThingClient;
import com.thingworx.communications.client.things.VirtualThing;
public class ThingworxProcessService extends Service {
public final String TAG = ThingworxProcessService.class.getName();
private Looper mServiceLooper;
private ServiceHandler serviceHandler;
private AndroidConnectedThingClient client;
private IntentServiceReceiver serviceReceiver;
@Override
public void onCreate() {
serviceReceiver = new IntentServiceReceiver();
HandlerThread thread = new HandlerThread("ThingworxProcessService", Process.THREAD_PRIORITY_BACKGROUND);
thread.start();
// Get the HandlerThread's Looper and use it for our Handler
mServiceLooper = thread.getLooper();
serviceHandler = new ServiceHandler(mServiceLooper);
@Override
public int onStartCommand(Intent intent, int flags, int startId) {
// For each start request, send a message to start a job and deliver the
// start ID so we know which request we're stopping when we finish the job
Message msg = serviceHandler.obtainMessage();
msg.setData(intent.getExtras());
msg.arg1 = startId;
serviceHandler.sendMessage(msg);
return START_STICKY;
@Nullable
@Override
public IBinder onBind(Intent intent) {
return null;
@Override
public void onDestroy() {
unregisterReceiver(serviceReceiver);
super.onDestroy();
// Handler that receives messages from the thread
private final class ServiceHandler extends Handler {
public ServiceHandler(Looper looper) {
super(looper);
@Override
public void handleMessage(Message msg) {
Log.i(TAG, "handleMessage Start");
try {
IntentFilter intentFilter = new IntentFilter();
intentFilter.addAction(Constants.ACTION_SHUTDOWN);
registerReceiver(serviceReceiver, intentFilter);
Bundle bundle = msg.getData();
long pollingRate = bundle.getLong(Constants.POLLING_RATE_EXTRA, 1000l);
boolean lastConnectionState = bundle.getBoolean(Constants.LAST_CONNECT_STATE_EXTRA);
String stateObserver = bundle.getString(Constants.CONNECTION_OBSERVER);
client = ThingworxService.client;
boolean isConnected;
while (client == null || !client.isShutdown()) {
if (client != null && client.isConnected()) {
isConnected = true;
for (VirtualThing thing : client.getThings().values()) {
try {
Thread.sleep(15000);
Log.v(TAG, "Scanning device");
thing.processScanRequest();
} catch (Exception eProcessing) {
Log.e(TAG, "Error Processing Scan Request for [" + thing.getName() + "] : " + eProcessing.getMessage());
Intent scanned = new Intent();
scanned.setAction(Constants.ACTION_SCAN_COMPLETE);
sendBroadcast(scanned);
} else {
isConnected = false;
if(isConnected != lastConnectionState){
if(stateObserver != null) {
Intent stateChange = new Intent();
stateChange.setAction(Constants.ACTION_STATE_CHANGED);
stateChange.putExtra(Constants.CONNECTION_OBSERVER, stateObserver);
sendBroadcast(stateChange);
lastConnectionState = isConnected;
Thread.sleep(pollingRate);
} catch (InterruptedException e) {
Log.e(TAG, "Polling thread exiting." + e.getMessage());
// Stop the service using the startId, so that we don't stop
// the service in the middle of handling another job
stopSelf(msg.arg1);
Log.i(TAG, "handleMessage End");
public class IntentServiceReceiver extends BroadcastReceiver {
@Override
public void onReceive(Context context, Intent intent) {
String action = intent.getAction();
if(action.equals(Constants.ACTION_SHUTDOWN)){
if(client != null && client.isConnected())
try {
client.shutdown();
} catch (Exception e) {
Log.e(TAG, "Error Shutting Down Client", e);
I apologize for my mistake
it was showing error in the beginning
but the real error was in gradle dependancies
then this thing works fine
I am extremely pleased with the way you have responded to my problem
Thank you so much.
Hope to get this support though out
Yeah this is why i was wondering if there was anything during the build process. Anyhow glad it has worked out for you.
