This widget could not be displayed.
thingworx license
AP_9587236
thingworx license
Since the support is closed for thingworx 8.5, does we will get new license for thingworx 8.5 to launch a instance in cloud??
4 REPLIES 4
cmorfin
(To:AP_9587236)
Hi @AP_9587236
I think it is best you open a case to the License department to confirm the situation.
You can open a case at https://support.ptc.com/apps/case_logger_viewer/cs/auth/ssl/log but make sure to Choose Licenses Services - Licensing for the Technical Area.
Christophe
can you please provide me the details here itself?
cmorfin
(To:AP_9587236)
Hi @AP_9587236
I do not have much details.
I would think you can generate a new license even for older version from https://support.ptc.com/apps/licensePortal/auth/ssl/index .
How if this does not work, you would need to contact the License team as indicated above. The License team does not monitor the Community so the way to contact them is by opening a case.
Thank you
Christophe
slangley
(To:AP_9587236)
Hi @AP_9587236
Even though support has ended for ThingWorx 8.5, you can still get updated licenses in the same way you do for the 8.4 you are currently running.  The licensing model has remained the same since ThingWorx 8.1.
--Sharon
