Hi everybody,
I want to know if it's possible implementing a tracking indoor with a head map in Thingworx.
I need a mashup like the following image. For example, I have a sensor in a wheelbarrow and in red is the zone where wheelbarrow is passing more often.
The problem is that the mashup must be in indoor.
- How can I perform this with the plane of the warehouse?
- Exist a extension or PTC Solution for that purpose?
- If the only way is with google map widget how can make it possible without the plane? (Show the map in general and zoom in the warehouse)
Thanks in advance
Luis.
Luis.
Hi @LuisCabello
Thank you for reaching out to PTC.
Please check this community post and see if it helps you with your use case
Toolika Dixit
Hi @LuisCabello
Toolika Dixit
