unable to connect ESP 8266 (wemos d1 mini) with thingworx
ajaygore
2-Explorer
i am using Wemos d1 mini an ESP8255 based board. i followed the tutorial name "Connect an Arduino Developer Board" and used the code given in it. By using Arduino IDE i compiled and upload the code in it with nesassary changes in code like wifi ssid name, password, server address and app key. but it is still not connecting.
here is the code
 * ESP8266_ThingWorx_REST_Demot.ino
 *  (c) PTC, Inc. 2016
#include <Arduino.h>
#include <ESP8266WiFi.h>
#include <ESP8266HTTPClient.h>
// WiFi Definitions //
const char WiFiSSID[] = "HAPL"; // WiFi access point SSID
const char WiFiPSK[] = "9822067XXX"; // WiFi password - empty string for open access points
// ThingWorx server definitions            //
//  modify for a specific platform instance //
const char TWPlatformBaseURL[] = "https://pp-18080610289k.devportal.ptc.io";
const char appKey[] = "2dc2799f-008d-42d0-9092-58943XXXXXX";
// Pin Definitions - board specific for Adafruit board//
const int RED_LED = 0; // Thing's onboard, red LED -
const int BLUE_LED = 2; // Thing's onboard, blue LED
const int ANALOG_PIN = A0; // The only analog pin on the Thing
const int OFF = HIGH;
const int ON = LOW;
// this will set as the Accept header for all the HTTP requests to the ThingWorx server
// valid values are: application/json, text/xml, text/csv, text/html (default)
#define ACCEPT_TYPE "text/csv"
//Attempt to make a WiFi connection. Checks if connection has been made once per second until timeout is reached
//returns TRUE if successful or FALSE if timed out
boolean connectToWiFi(int timeout){
  Serial.println("Connecting to: " + String(WiFiSSID));
  WiFi.begin(WiFiSSID);
  // loop while WiFi is not connected waiting one second between checks
  uint8_t tries = 0; // counter for how many times we have checked
  while ((WiFi.status() != WL_CONNECTED) && (tries < timeout) ){ // stop checking if connection has been made OR we have timed out
    tries++;
    Serial.printf(".");// print . for progress bar
    Serial.println(WiFi.status());
    delay(2000);
  Serial.println("*"); //visual indication that board is connected or timeout
  if (WiFi.status() == WL_CONNECTED){ //check that WiFi is connected, print status and device IP address before returning
    Serial.println("WiFi connected");
    Serial.println("IP address: ");
    Serial.println(WiFi.localIP());
    return true;
  } else { //if WiFi is not connected we must have exceeded WiFi connection timeout
    return false;
//create a name for the board that is probably unique by appending last two bytes of MAC address
//return name as a String
String getUniqueDeviceName(){
    String uniqueName;
    uint8_t mac[WL_MAC_ADDR_LENGTH];
    WiFi.macAddress(mac); // WiFi does NOT need to be connected for this call
    String macID = String(mac[WL_MAC_ADDR_LENGTH - 2], HEX) +
                    String(mac[WL_MAC_ADDR_LENGTH - 1], HEX);
    macID.toUpperCase();
    uniqueName = "ESP8266Board-" + macID;
    Serial.println("DeviceID>" + uniqueName);
    return uniqueName;
// make HTTP GET to a specific Thing and Propertry on a ThingWorx server
// thingName - Name of Thing on server to make GET from
// property - Property of thingName to make GET from
// returns HTTP response code from server and prints full response
int httpGetPropertry(String thingName, String property){
        HTTPClient http;
        int httpCode = -1;
        String response = "";
        Serial.print("[httpGetPropertry] begin...");
        String fullRequestURL = String(TWPlatformBaseURL) + "/Thingworx/Things/"+ thingName +"/Properties/"+ property +"?appKey=" + String(appKey);
        http.begin(fullRequestURL);
        http.addHeader("Accept",ACCEPT_TYPE,false,false);
        Serial.println("GET URL>" + fullRequestURL +"<");
        // start connection and send HTTP header
        httpCode = http.GET();
        // httpCode will be negative on error
        if(httpCode > 0) {
            response = http.getString();
            Serial.printf("[httpGetPropertry] response code:%d body>",httpCode);
            Serial.println(response + "<\n");
        } else {
            Serial.printf("[httpGetPropertry] failed, error: %s\n\n", http.errorToString(httpCode).c_str());
        http.end();
        return httpCode;
// makes HTTP POST to platform to CreateThing service using input string as the new Things's name.
// Returns server response code
int createThing(String nameOfThing){
        HTTPClient http;
        int httpCode = -1;
        Serial.print("[createThing] begin...");
        String fullRequestURL = String(TWPlatformBaseURL) + "/Thingworx/Resources/EntityServices/Services/CreateThing?appKey=" + String(appKey);
        http.addHeader("Content-Type","application/json",false,false);
        Serial.println("POST URL>" + fullRequestURL + "<");
        httpCode = http.POST("{\"name\": \""+ nameOfThing +"\",\"thingTemplateName\": \"GenericThing\"}");
        if(httpCode > 0) {
            Serial.printf("[createThing] response code:%d body>",httpCode);
        } else {
            Serial.printf("[createThing] POST... failed, error: %s\n\n", http.errorToString(httpCode).c_str());
        http.end();
        return httpCode;
// make HTTP POST to ThingWorx server Thing service
// nameOfThing - Name of Thing to POST to
// endPoint - Services URL to invoke
// postBody - Body of POST to send to ThingWorx platform
int postToThing(String nameOfThing, String endPoint, String postBody){
        HTTPClient http;
        int httpCode = -1;
        Serial.print("[postToThing] begin...");
        String fullRequestURL = String(TWPlatformBaseURL) + "/Thingworx/Things/"+ nameOfThing +"/Services/"+ endPoint +"?appKey=" + String(appKey);
        Serial.println("URL>" + fullRequestURL + "<");
        Serial.println("[postToThing] POST body>" + postBody + "<");
        httpCode = http.POST(postBody);
        if(httpCode > 0) {
            Serial.printf("[postToThing] response code:%d body>",httpCode);
        } else {
            Serial.printf("[postToThing] POST... failed, error: %s\n\n", http.errorToString(httpCode).c_str());
        http.end();
        return httpCode;
void setup() {
    pinMode(RED_LED, OUTPUT);
    pinMode(BLUE_LED, OUTPUT);
    Serial.begin(115200);
    Serial.setDebugOutput(true);
    Serial.println();
    Serial.println();
    Serial.println();
    Serial.printf("Starting...\n");
    for(uint8_t t = 4; t > 0; t--) {
        Serial.printf("   WAIT %d...\n", t);
        Serial.flush();
        delay(1000);
    connectToWiFi(10);
void loop() {
    String thingName = getUniqueDeviceName(); // get a unique name for this Thing so that many can work woth one ThingWorx server
    while (WiFi.status() == WL_CONNECTED) { // confirm WiFi is connected then loop forever as long as WiFi is connected
      int getResponseCode = httpGetPropertry(thingName, "SomeNumber");
      if (getResponseCode == 404){ // a 404 response indicates successful connection to TW platform but either no Thing or no property yet
        // first we will try to create a new Thing on the platform
        int postResponseCode = createThing(thingName); // saving the response code in case we want to add retry logic in the future
        //  the newly crated Thing has to be enabled
        postResponseCode = postToThing(thingName,"EnableThing","");  // no POST body needed for EnableThing endpoint
        // after the new Thing is enabled it must be restarted
        postResponseCode = postToThing(thingName,"RestartThing","");  // no POST body needed for RestartThing endpoint
        // add a property to the Thing                                  3rd parameter looks ugly because required quotes in JSON are escaped with backslashes
        postResponseCode = postToThing(thingName,"AddPropertyDefinition", "{\"name\":\"SomeNumber\",\"type\":\"NUMBER\"}");
        //POST body contains JSON object with property name and property type
        // after changes to a Thing's structure it must be restarted
      delay(2000);
    }// end WiFi connected while loop
    Serial.printf("****Wifi connection dropped****\n");
    WiFi.disconnect(true);
    delay(10000);
    connectToWiFi(10);
I am not able browse to the ThingWorx server listed in your code. The Developer Portal servers are automatically shut down after a few hours of inactivity and must be restarted by logging in to your account.
Did your code output any messages in the serial console?
i tried it when my server is running, as shown in course"Connect an Arduino Developer Board" the output expected on console doesn't not match with the output that i get.also the new thing should be shown in platform name "ESP8266Board-XXX where XXXX replaced by the last 4 digits of boards WiFi MAC address. i attached the screenshot of console output.
ehrovoski
(To:ajaygore)
Hello ajaygore,
I'm running into the same issue, and I'm going through the same tutorial with my Wemos D1 mini chip.
I had the same results in the screenshot that you're getting. After some digging, I found that the code isn't passing the wifi password when it tries to connect.
So you'll edit the WiFi.begin(WiFiSSID); line:
From this:
To this:
WiFi.begin(WiFiSSID, WiFiPSK);
In Aruduino IDE, when you use the WiFi.begin command, it's expecting the network name and password as inputs.
So the typical call looks like this:
WiFi.begin("SSID", "Password");
I hope this helps!
Cheers
