unable to set spaces in grid columns(Adv grid) in TWX 8.5.0
VaibhavShinde
Hi ,
I am unable to see columns in Configure grid columns window ,  i have used external database and  getting data using query service  . output will be in infotable. already i have bound all data to grid and i can see data in grid . but i want some space in Grid columns you can see attached files.
Try to create datashape with the button +DataShape that is visible after executing your service.
After this, use the new datashape in the output of your service and save.
Hope it helps,
Raluca Edu
3 REPLIES 3
You cannot configure grid columns as the result has no data shape attached.
Please add a datashape to the data that you bind with the adv grid and you will be able to Configure Columns.
Hope it helps,
Raluca Edu
Hi ,
Thanks for reply,
I have checked with attaching datashape in  output of a service. still its not showing columns in configuration window.
Hope it helps,
Raluca Edu
