Hi ,
I am unable to see columns in Configure grid columns window , i have used external database and getting data using query service . output will be in infotable. already i have bound all data to grid and i can see data in grid . but i want some space in Grid columns you can see attached files.
Try to create datashape with the button +DataShape that is visible after executing your service.
After this, use the new datashape in the output of your service and save.
Hope it helps,
Raluca Edu
You cannot configure grid columns as the result has no data shape attached.
Please add a datashape to the data that you bind with the adv grid and you will be able to Configure Columns.
Hope it helps,
Raluca Edu
Hi ,
Thanks for reply,
I have checked with attaching datashape in output of a service. still its not showing columns in configuration window.
Hope it helps,
Raluca Edu
