I followed the instructions to uninstall Thingworx Analytics Server and then on the new install I get the following error:
There has been an error.
Unknown error while running/default/json_utils-configfile=/results-ms_report.json - property=version.
Any ideas how to fix this?
Seems like the problem described in this article: https://www.ptc.com/en/support/article?n=CS288520&source=Case%20Viewer
