hello all,
I'm using thingworx 9.5 and I'm trying to configure it for displaying a tree, It's not clear for me the needed infotable and how I need to configure the ptcsgrid widget for this.
any hint, example, tutorial, documentation is apreciated
Hi, @AK_10638440 Can you take a look at the below article and let us know if it will work in your case or not?
Hi Surya,
the tree grid advanced you proposed is a legacy widget in Thingworx 9.5. I'm trying to use the new grid widget which can be used for a tree view also, but I'm not sure how
Hi @AK_10638440 Thingworx has a tree widget also, can you take a look if it can fulfill your use case, I will try your above scenario and let you know my findings.
I know about tree widget, but the grid are more customizable, so I would prefer that.
If i remember correctly, you have to provide the column names for parentId maybe also HasChildrenFieldName.
ChildData can be the same infotable as Data.
