using ptcsgrid for displaying a tree grid
AK_10638440
hello all,
I'm using thingworx 9.5 and I'm trying to configure it for displaying a tree, It's not clear for me the needed infotable and how I need to configure the ptcsgrid widget for this.
any hint, example, tutorial, documentation is apreciated
11 REPLIES 11
Hi, @AK_10638440  Can you take a look at the below article and let us know if it will work in your case or not?
https://www.ptc.com/en/support/article/CS329539
Hi Surya,
the tree grid advanced you proposed is a legacy widget in Thingworx 9.5. I'm trying to use the new grid widget which can be used for a tree view also, but I'm not sure how
Hi @AK_10638440  Thingworx has a tree widget also, can you take a look if it can fulfill your use case, I will try your above scenario and let you know my findings.
Hi @Surya_Tiwari
I know about tree widget, but the grid are more customizable, so I would prefer that.
Rocko
(To:AK_10638440)
If i remember correctly, you have to provide the column names for parentId maybe also HasChildrenFieldName.
ChildData can be the same infotable as Data.
iguerra
(To:Rocko)
An example of the data to be used and related fields would be very appreciated
Rocko
(To:iguerra)
Service getTree:
result = Resources["InfoTableFunctions"].CreateInfoTable();
result.AddField({name:"id", baseType:"INTEGER"});
result.AddField({name:"parentId", baseType:"INTEGER"});
result.AddField({name:"name", baseType:"STRING"});
result.AddField({name:"hasChildren", baseType:"BOOLEAN"});
result.AddRow({id:1, name:"Europe", hasChildren:true});
result.AddRow({id:2, parentId:1, name:"CER", hasChildren:true});
result.AddRow({id:4, parentId:2, name:"Germany"});
result.AddRow({id:5, parentId:2, name:"Switzerland"});
result.AddRow({id:3, parentId:1, name:"NER", hasChildren:true});
result.AddRow({id:6, parentId:3, name:"Sweden"});
Binding:
wcui
(To:iguerra)
@AK_10638440
Please check below link for steps to display tree with Grid widget in ThingWorx 9.6
https://support.ptc.com/help/thingworx/platform/r9.6/en/index.html#page/ThingWorx/Help/Mashup_Builder/Widgets/Grid_AddingAGridWidgetToaMashupdita.html#
Also, Rocko shared an example how to create data source for Grid.
Rocko
(To:wcui)
iguerra
(To:Rocko)
Thank you  @Rocko
I was able to get it working.
wcui
(To:iguerra)
@iguerra
It appears that Rocko answered your question.  For the benefit of other Community Members who may have the same question, it would be great if you could designate it as the Accepted Solution.
In the event that this response did not answer your question, please post your current status so that we can continue to support.
Thanks for using the PTC Community!
wcui
