Same as above
Means when one user login ed into composer he is able to see 4 users and when another login ed he is able to see 3 users. The widgets which are invisible they are taking the space. Is there a way for resizing the widgets according to req so that empty spaces don't come in the mashup
Since you are hiding the widgets, the blank space will unfortunately be present. Please take a look at the usage of dashboards, and see if that might be applicable for your use case.
Is there any script or extensions which we can use for resizing as explained above
Hi Ravi,
Is there a way in dashboard to remove the extra space in between the dashboards and gadgets.
Here also we are facing the same problem regarding the extra spaces.
Aditya
