from the thingworx docker build, the scripttimeout was set to 30 in the generated platform-settings.json. I had combed through all references and "full" list I could find, but none of them mentioned the env key name for scripttimeout. I had done a blind test with "SCRIPTTIMEOUT=1220" in the docker compose yaml file, but it didn't work, just got ignored.
That's the same issue I hit as well some time ago.
There is no programmable key for the script timeout as of now, but you can use the override capability of docker.
(continuing this idea, if this enhancement request to our docker files is critical for you, please raise a Tech Support ticket)
Create an override file and put the following in your docker-compose.override.yml file:
version: '2.3'
services:
platform:
environment:
- SCRIPT_TIMEOUT=<timeout_in_seconds>
Note that I'm not sure about the exact syntax (meaning if you need to add only that line or the whole environment section), but you can find these answers in here https://docs.docker.com/compose/extends/
version: '2.3'
services:
platform:
environment:
For the benefit of others, may I kindly ask you if you needed to perform any modifications from my suggestion above in order to make it work?
I'm specifically not sure if it's only the variable that needs to be added or something else as well.
right after I knew there was no env key for scripttimeout, I made a small change to the deploy_entrypoint.sh , and then I could tweak the platform-setting.json file .
