what is the role of kepserverex?
Newbie
I recently started browsing about kepserverex. I have few questions in my mind
first of all is kepserverex a opc client software or a opc server
and secondly when used with thingwork what would be architectural flow of the whole
would it be sensor->kepserverex->thingworx
any references on how can I use kepserverex with thingwork?
Thank you for any reply
Re: what is the role of kepserverex?
Hi Jugal,
KepserverEX it's a  OPC Client and a OPC Server, plus it has plenty of Plug-ins to communicate with different Industrial protocols ( BACNet, ModBus,.... )
And the communication flow it's how you said, but it's bidirectional, you can read data from sensor and through Kepserver send to ThingWorx and ThingWorx write data to the sensor.
Best Regards,
can you provide me some reference for how to operate with kepserverex?
Jugal Shah​,
Here is some configuration guide and exmaple to connect Kepware with ThingWorx:
Connect Kepware with ThingWorx
Br,
Anna
Hi Carles,
Could you please help me out as to how to write back values to Kepware tags from Thingworx?... i am able to fetch them fine.
Archisman
Thingworx Navigate content has a new home! Click here to access the new Thingworx Navigate forum! ______________________________
