I replace SET tablespace_location=C:\ThingworxPostgresqlStorage
but didn't work plz help me
how can i get thingworx composer?
You can get ThingWorx from our support portal: https://support.ptc.com/appserver/auth/it/esd/index.jsp
seonho Cha Could you describe us a bit more in details what exactly the problem is, along with the actions you proceeded with, so far? Thanks!
i following staka's video and download tomcat 8.0.42, postgresql 9.4, Thingworx-platform-postgre-7-1-10 on PTC support page
but when i excute thingworxPostgresDBSetup.bat (i replace loacation "\ThingworxPostgresqlStorage" -> "C:\ThingworxPostgresqlStorage")
apeer some error
psql:./thingworx-database-setup.spl:1: ERROR: tablespaace "thingworx" already exists
psql:./thingworx-database-setup.spl:14: ERROR: could not create directory "pg_tblspc/16394/PG_9.4_201409291/16409": No such file or direcrory
psql:./thingworx-database-setup.spl:14: ERROR: database "thingworx" does not exist
i make directory called ThingworxPostgresqlStorage in root
and i create new role user "twadmin"
but i can't make new database"thingworx" and new schema "thingworx"
so, i can open appmanager /Thingworx on Tomcat localhost
please help me why didn't make database and schema . thank for your kind.
ps. i give Administrator rights each folder ThingworxPostgresqlStorage and thingworxPostgresDBSetup.ba
Is this a fresh install? If so, try running the Delete/DatabaseCLeanup script first, then the installation ones.
Also please refer to this article:Frequently Seen Errors upon launching the Thingworx application:
Thanks , i trying
