when I am trying to install thingworx,using installer it is by default taking c drive , and we want to install it in D drive , what should we change?
If you are using the installer executable, you can pass it the --help parameter. This will list all available parameter, including --installdir which you can use to define the target installation directory.
Hi @Shivam_P_Singh.
When you run the installer, you have the ability to type over the drive designation. Please let us know if you still have issues, and if so, provide a screenshot.
--Sharon
