when migrating thingworx from on prem to azure cloud show we change the database name of sql or not
KSM
we are migrating thingworx from on prem to azure, thing Worx installed with mssql server database. I am installing mssqlserver database in azure vm,
now I have the doubt of while creating sql server instance and database name, do I need to give the same sqlserver instance and database name exactly like on-prem? If we give same names, then is there any impact?
KSM
yalmatar
(To:KSM)
Hi @KSM ,
you can give them different names, this will be ok, using the same names can simplify the migration process and minimize the impacts.
regards
Yasin
Hello @KSM,
You have a reply on your topic. If the reply helped you solve your question please mark it as the Accepted Solution.
Community Moderation Team.
